Flix 0 Posted March 17, 2008 Hi I removed my fuel tank on my 1.9 GTI to fit a rollcage.I cut the original hoses off the fuel pump as I'm going to replace them with new ones. Now I've refitted the tank and can't remember which one is which. Knew I should have marked them. Can anyone tell me which one is the outlet. Thanks in advance. Share this post Link to post Share on other sites
Pugnut 9 1 Cars Posted March 17, 2008 HiI removed my fuel tank on my 1.9 GTI to fit a rollcage.I cut the original hoses off the fuel pump as I'm going to replace them with new ones. Now I've refitted the tank and can't remember which one is which. Knew I should have marked them. Can anyone tell me which one is the outlet. Thanks in advance. blow back down the pipes . the supply has a non return valve . the return will be free to blow back into the tank Share this post Link to post Share on other sites
Flix 0 Posted March 17, 2008 Great idea, thanks for that. Share this post Link to post Share on other sites
Flix 0 Posted March 18, 2008 blow back down the pipes . the supply has a non return valve . the return will be free to blow back into the tank Worked a treat the rear pipe is the outlet. Share this post Link to post Share on other sites
