smokey
Do I Need Two Fans For A Mi 16 Conversion
smokey
Hiya guys
Stripped down the front of my CTI ready to take out the old engine and i noticed i only have 1 fan. Probably due to it being a 1.6.
Anyway the cowling has 2 sections for fans so i was wondering should i get a 2nd fan seeing i'm putting a Mi 16 in?
If i do do both fans run separatly or are they joined but a rubber band?
Daxed
Single fan will be fine.
Bakes100
yep.. got a single fan on my 6. Works fine, try and get hold of a fan switch that kicks in lower though as these help!
The two fan setup is cool. On low speed they're hooked up in series. Then on high speed they hook up in parallel.
C_W
They all have space to accommodate two fans but the 1.9GTi had an oil cooler in the left hand space whereas the 1.6 a cooler. One fan is fine though.
In the UK one fan is fine but in much hotter climates two might be a better idea. Peugeot certainly thought so, they fitted twin fans in certain parts of the world.
Spiky
where from dude?
Bakes100
Your local motor factors or somewhere like that! They have a list of the different temperatures, my high speed fan kicks in at around 95 iirc. i think there is about 5 different ones.
Make sure you get the correct one for your plug type though as the older ones are different.
Pug do them but they are about 25-30 quid ..!! as opposed to 9 quid :blush:
Daxed
My Pug dealer offered me different temp fan switches, the plastic coloured band was a different colour for the different temperatures. The price varied massively dependant on which temp one.
Spiky
thanks both, will go have a butchers in my locl place :blush:
Ryan
One fan should be more than enough as long as the cooling system is up to scratch.
Coonper
Ive got one working off standard thermostat and i have another which is controlled manually by a switch on the dash.
