oli-pug
Speed Sensor On Xsara Vts Box
oli-pug
Hi, does anyone know which type of speed sensor a vts box uses?
I'm thinking of using this box in my conversion, but i read somewhere i'll need to swap the n/s inboard cv joint? Which ones will fit a 309 gti shaft?
Edited by oli-pug
it uses the same speed sensor as the GTi6, i.e purely electrical.
not sure what that has to do with the driveshaft though!
oli-pug
right cheers, i'll have a look down the scrappy tomorrow for a cable one then
if you're going gti6 you need the one that drives the cable and has an electrical connection.
All Praise The GTI
yeah as said above need a sensor with both. 306 xsis have them i know that much.
i thought my 309 shafts were ok in the vts box till cme home other day and noticed a puddle :D just swapped inner joint with the vts one luckily i stil had earlier
Alastairh
Check a late ZX DT with a keypad. They also have these sensors on :D
