monty69
S16 Head Oil Return Leaking
monty69
Just found a threaded plug in side of head(near dizzy) bogged up and leaking oil. Pulled it out and the hole in head isnt threaded, another quality bodge. Does anyone know what can be used to block the hole without resorting to silicone. Every week i find more bodges on this car B)
nick
Stick the plug back in with Araldite or chemical metal.
Nick
S16's aren't meant to have a Dizzy, that hole is usually the drain for the vacuum pump so whatever you can find to do the job will suffice B)
monty69
Cheers guys il try some proper sump sealer B)
