All Praise The GTI
8v Turbo Flywheel And Clutch Bolts
All Praise The GTI
i know i need 6 m7 bolts i think for the clutch cover plate on my turbo lump but which bolts do i use to attach the flywheel?
engine came out an xm turbo automatic
Rob Turbo
According to servicebox they are m9x1.00, 22mm long, IIRC the heads are quite short though, not sure if using regular bolts will cause a problem.
If you want to get them from pug, the part number is 0537.40 and they are 58p each
All Praise The GTI
thanks for that mate. i have the bolts that held the torque converter on but not sure if they long enough for the flywheel. will have to check what they were.
any ideas on my other post, which pulley to use when i swap the cams?
nat
Rob Turbo
They will both have the same number of teeth, it will just be the timing that's altered if anything, i.e. the slot that aligns it on the cam will be slightly different, not sure which would be best to use but I'm going to use the one from the turbo engine.
All Praise The GTI
ok thanks for the advice. ill tell them to swap the too pulleys then
tom_m
i just used normal xu10 flywheel bolts, and what ever came with the mi clutch worked on the clutch because i used an mi flywheel
Edited by tom_m
