[Project] Starting My Xu5T Build
Woooo more shineys from postman pat today!!!!
35736441500_fd0c197549_z.jpg205T by Tom Fenton, on Flickr
j_turnell
Nice! its coming together well! look forward to see the engine in.
platty
Where did you get the fuel lines/fittings from Tom?
Thats next months expenditure for me.
Downpipe looks very clean and tidy :D
Thats all actually for the brake lines, I sourced them via a hydraulic supplier I spend a lot of money with at work, they did a deal on it all for me, even so it was still £60-odd. I'm pleased with the downpipe, apart from the flange to the turbo which is cast steel it is all stainless.
BackStreetRacecars
this build gets better every read!! lovving the progress... can i ask Tom what do you do?
M@tt
he's a gigalo! very reasonable rates i hear.
Dirty finger nails though!!
BackStreetRacecars
damn good at tig welding from being a giggolo then eh.... thought they could only mma....
M@tt
:unsure:
i'm sure he'll be along shortly to tell you his correct job title but i know he works as a manger in a dirty great Corus steel foundry in Shef
Unfortunately although a gigalo would be more entertaining, I actually work in engineering for the melting shop at a steelworks.
DrSarty
I think you ARE a gigolo.
You are wooing your 1.6 into a whirlwind romance with a turbo. You could say, through induction, you are forcing her to suck harder (?). :unsure:
GROAN!!!
phil withers
Having known Tom for far too long, I can honestly say he is much better at fixing cars than being a gigalo - probably :)
Damn, its a fair cop :rolleyes:
Bulkhead stiffening plate has been tonights job
First clamp in place and mark out the holes from inside
36128268775_c292fe3474_z.jpg205T by Tom Fenton, on Flickr
Gives you this
35994501861_e715b5efbe_z.jpg205T by Tom Fenton, on Flickr
Then centre pop and drill the holes, TBH I was suprised it didn't come already drilled.
Clean off the paint where it will need welding and spray in weld thru primer
35320018053_1dfd21bc22_z.jpg205T by Tom Fenton, on Flickr
Weld into place. Since I got my TIG I've hardly used my MIG. Therefore my MIG welding has gone to sh1t! Oh well its certainly strong if not neat
Blast over with some rattle can rouge, done!
35320017983_64c68312ef_z.jpg205T by Tom Fenton, on Flickr
Well it has been one of those days today, when it seems like I've spent all day on the car, but there is not a lot to show.
The pedal box is now bolted in place, and I have made up and fitted the -4 aeroquip from the remote reservoirs to the master cylinders.
35736441600_1b9e36f297_z.jpg205T by Tom Fenton, on Flickr
With that done I did some heat protection, the fuel lines have been sleeved, I've made up a bit of a shield to sit in front of them, and I've also wrapped the clutch cable in the "hot" area. Should all help things survive.
35994502221_c775c79085_z.jpg205T by Tom Fenton, on Flickr
I then set about the calipers, I'd made a bit of a start cleaning them up but cracked on with them this afternoon and then painted them.
36128268795_aacc64dbaa_z.jpg205T by Tom Fenton, on Flickr
Final job was to start taking off the old suspension and brakes, from standard 1600 it is going to 309 arms and shafts, 1900 uprights, and 266mm brakes.
Whilst doing this I also discovered the rack is buggered, I do have a spare in the shed so I'll have to dig that out and see if it is any good or not.
edbar
Looking good Tom! :)
Bit more progress to report
309 wishbones, 1900 hubs, and 266mm brakes fitted
35994501931_e0aae750fd_z.jpg205T by Tom Fenton, on Flickr
Whilst I was messing with the wishbones, I fitted a lower brace I've had for about 12 months! I'm not convinced it will do much from the design of it, the bar seems to hang out in front of the pickups too far to achieve much really.
36128269675_12678fb086_z.jpg205T by Tom Fenton, on Flickr
Then finished off the braided lines to the brakes, well nearly, just need one more fitting to finish.
35994501961_fe9127ab7c_z.jpg205T by Tom Fenton, on Flickr
Soon it will be engine back in time..........
Edited by Tom Fenton
New steering rack arrived and fitted, I wasn't terribly impressed by the standard of finish, but then it was £42.
PICTURE MIA
I've also made a small plate to fill the large hole that the loom usually goes through, I need to order another gland fitting to go next to the one that is there. Fiddly to bolt in but will keep the noise out.
35736441660_903e492903_z.jpg205T by Tom Fenton, on Flickr
Next I turned my attention to the diff. First off took it apart, it was on 60/30 ramps which aren't ideal for a road car! It had supposedly been just rebuilt, and on taking it apart this showed to be true with new plates in it.
36128268905_1870779b14_z.jpg205T by Tom Fenton, on Flickr
Next fitting the diff bearings, a simple job with a press, and those of you that own one of my torsion bar pullers will be pleased to hear that it will also double up as a suitable press tool to fit diff bearings as well!
36128268895_794dba8811_z.jpg205T by Tom Fenton, on Flickr
Then I trial fitted the diff to see how much the casing needed trimming. Here shown the area in question
35994502031_7b54251864_z.jpg205T by Tom Fenton, on Flickr
I used my trusty powerfile, didn't need much off at all in the end.
35320018113_30d98ddf76_z.jpg205T by Tom Fenton, on Flickr
Well since the last installment the diff is now built and in the box, and the box is now sat on the end of the engine with the clutch installed, I've never tried putting the engine and box in the car as one, but people have said it can be done, so I'm going to give it a try.
Aside from all that I've a clutch to change on a 306 GTI6 and it has dawned on me that I've no way of moving the 205 out of the garage now, as I've no 15" wheels to go on the front to clear the brakes. So with this in mind I thought I had better pull my finger out and get on with the wheels.
I've very little to no patience when it comes to paint prep so they won't be perfect, but here is where I am at
Wheels prepped with the DA, luckily for me the majority of them could be done with the DA rather than by hand! 180 then 320 grit, then 600 grit wet. Also dressed the outer rims up with the DA to get rid of any nasty scuffs.
35736441720_8188fc98a7_z.jpg205T by Tom Fenton, on Flickr
Next a drop of etch primer
35736441700_7d614532d6_z.jpg205T by Tom Fenton, on Flickr
And finally for tonight some 2k basecoat, in this case EVE silver which I believe is the original colour for these wheels?
35994502161_1569b77a48_z.jpg205T by Tom Fenton, on Flickr
They are by no means mint but should look presentable enough for my old shed. Will need clear lacquer tomorrow, I'm just off out now to give them another coat of silver.
EdCherry
You can fit the engine and box in together, I found that it had to sit with the gearbox at a slight angle down, has to go in with the gearbox pointing at the bulkhead and lowered slowly while you turn it to go under the tray, then with a jack just make it level and start bolting stuff in!
Good progress tom, not long to go now!
tom_m
dead easy tom, it's the only way i do it, sod farting about with the box first.
it's easier if you unbolt the gearbox mount tray first, drop the engine in like ed says box down, once straight lower it in the bay and try and line up the lower mount at this point. if you're keeping the lower brace it's a handy place to sit the gearbox while you bolt the tray back in. then lift it up to attach the gearbox mount and drop it back on to the top mount.
WOO shiny lacquered wheels
35320018343_451e046a56_z.jpg205T by Tom Fenton, on Flickr
Well I've had a busy weekend but not on the car, on Saturday we were fitting some new Ti bottom arms to my mates Fiesta, super sexy and much better geometry!
36128269155_ac56abf78d_z.jpg205T by Tom Fenton, on Flickr
Anyway I've had a hour or two this afternoon on my car. Because I'm going to 1900 wheels I wanted to change the rear brakes to discs to get the offset right so the wheels sit properly in the arches, I think they don't look right when used on a 1600 beam.
So I had a dig through my selection of crap to see what I could make a beam out of, came up with a pair of Xsara VTS rear trailing arms, one with a decent shaft, a 309 cross tube, a pair of vented front discs, and a knackered pair of 1600 front Bendix calipers.
Being the tight git I am I decided to see if I could fit the new discs I had to use them, rather than forking out for a new pair of rear discs.
So lo and behold
36128269145_dcc376fde1_z.jpg205T by Tom Fenton, on Flickr
and
35286745164_9d494816f5_z.jpg205T by Tom Fenton, on Flickr
I also started cleaning up one of my 309 beam tubes, this one was in very clean condition, a wipe over with a rag and some duck oil and it looked like this! I'm wondering if it was replaced at some point as it certainly doesn't look 15 years old.
35736441830_9b34572b9c_z.jpg205T by Tom Fenton, on Flickr
DrSarty
Duck murderer!
Bom bom!
