robgti 0 Posted March 10, 2008 Hi all my front washers recently stopped working so i got a new pump and tried that and they still dont work. The wipers still work but was wondering if any one had any ideas to why the pump wont? Share this post Link to post Share on other sites
welshpug 1,666 Posted March 10, 2008 dirty connection, or earth. I had the same problem with mine last week. Pull the plug off the motor and clean the spade terminals inside it (scrape away the corrosion), and check the condition of the earth point behind the headlamp on that side. Share this post Link to post Share on other sites
robgti 0 Posted March 10, 2008 i have actually took the plug off and put two new connectors on and still nothing. Could it be something wrong with my stalk? Share this post Link to post Share on other sites
Hardgraf 0 Posted April 8, 2008 I have exactly the same problem! Share this post Link to post Share on other sites
Baz 421 Posted April 8, 2008 The stalks also fail, if you pull the stalk as if to work the washers and the wipers don't wipe, then it's the stalk. If you bridge a live straight to the pump it will tell you if it works or not. Share this post Link to post Share on other sites
Tom Fenton 1,548 Posted April 8, 2008 9 times out of 10 in my experience the cause of this problem is the s*itty earthing point on the headlight panel. Share this post Link to post Share on other sites
andrewhewitt 3 Posted April 8, 2008 thats what caused mine to stop. give it a clean and it will start working again Share this post Link to post Share on other sites
PhilCTI 1 Posted April 8, 2008 I had the same problem and it was down to the earth wire, even after cleaning, it still occasionally stopped working so I ran a new earth wire to it and its been fine ever since, Share this post Link to post Share on other sites
craig f90 0 Posted April 8, 2008 The stalks also fail, if you pull the stalk as if to work the washers and the wipers don't wipe, then it's the stalk. If you bridge a live straight to the pump it will tell you if it works or not. Ive had 2 stalks go on me. Second hand ones though. If you think its the stalk, flick it like mad whilst listenening out for a noise from the pump. It worked for me Share this post Link to post Share on other sites
