shooter mcgavin
Do 6 Brakes Take 205 Flexi Pipes
shooter mcgavin
going to order some braided brake lines this week and fit my gti6 front calipers
do the calipers take the same ends as the 1.9 205 lines
cheers
GTI6BOY
yep
cybernck
ideally, you should get them made a little bit longer than standard, by about an inch :unsure:.
I know this will sound like a sales pitch as I stock them, but the 205 one's Do Not Fit Correctly and should fail a MOT as on lock the pipes crimp up meaning Little no Brakes on that side, Considering your upgrading the Caliper's the Pipes should be correct too.
sussex_gti
How much do you sell them for Miles?
They are £35.00 a pair to Forum member's, They are PVC Covered braded lines with Stainless steel fitting's
Bakes100
I used to have standard 205 flexi pipes and when i checked they were stretched far too much!
I brought some of miles' stainless ones and they fitted a treat :unsure:
Emmy Seize
I used a complete Googridge kit without any issues -the MOT people liked it, too.
gary205
Thanks Miles, Just ordered a pair of these. One of those things I need to finish the Mi16. It's been a bit neglected since I bought another 205 last year. Need to get it finished and on the road soon!
GTI6BOY
i was saying yep to that...sorry
CaptainK
I might get you to fit some of them if and when the car ends up with you. Obviously for some extra dollar. :huh:
sussex_gti
Do you do the rears as well Miles? Mines a 1.9 so need all six hoses ideally.
All Praise The GTI
yeah id also be interested in a set of 6 if you do them. that would be longer ones for 6 calipers at the front and 4 for the rear.
would save me buying another goodridge kit and some longer fronts from you which would cost a fortune in total!
v6Max
Just a word of recommendation for Miles; I've had a full set of braided hoses from him and then another bunch of hoses so that I can run the rear lines in the car. Quality is excellent; much better than the Goodridge hoses I have fitted to my v6 and the service from Miles has been excellent - he's not even shown a hint of frustration at all my newby questions...
