kaich
Mistake In Dismantling Mi16
kaich
That's the problem
I have a spare xu9j4 that I'm dismantling. I had removed timing belt without set the timing pin holes :)
so if I try to rotate the crankshaft, I risk to bend valve or whatelse?
At now can I remove the head or I must to set the engine with the timing pin holes (like Haynes says) before remove the head?
Edited by kaich
woodsy
yeah you can remove the head without lining the pins up it aint a problem mate.
kaich
that's fine mate! :)
I hope only that there's no problem with valves, because my brother just said me that he tried to rotate cranksfhat 5 min ago :) holy s###t
woodsy
you would feel the valves touching when u turned it over by hand as it would lock up
kaich
as I asked him , he turned a half clockwise the crankshaft, but he said to heard nothing :)
tomorrow I'll remove the head, let's hope to see nothing bent valves
