andykandy205 0 Posted March 9, 2008 Does any body know the product number for the dust seal that goes on the drive shaft cause my local peugeot dont have a clue what im talking about Share this post Link to post Share on other sites
Tom Fenton 1,548 Posted March 9, 2008 Dust seal on the driveshaft? I'm not sure what you mean either? Do you mean the CV gaiter that goes around the driveshaft joint? Or do you mean the seals in the gearbox that seal against the driveshaft to stop the gearbox oil leaking? Share this post Link to post Share on other sites
andykandy205 0 Posted March 9, 2008 (edited) the seal that buts up to the gear box on the drivers side driveshaft to stop the gear box oil leaking Edited March 9, 2008 by andykandy205 Share this post Link to post Share on other sites
Miles 331 1 Cars Posted March 9, 2008 If you mean the flap thing then just ditch it as it does nothing and isn;t fited to newer models, 406, 306 etc Or the Drive shaft oil seal, 306 S16's & GTi's etc use the same one so order one for that as it may help Share this post Link to post Share on other sites
j_turnell 137 3 Cars Posted March 9, 2008 Yeh does bugger all anyway, not needed, if you have a leak, juts replace the d.shaft seal as this will be the culprit. Share this post Link to post Share on other sites
