rapidmi 4 Posted March 6, 2008 (edited) my wee 1600 keeps cutting out any time i come up to a junction and the revs are ment to drop down to idle speed they just keep dropping and it cuts out, even if am driving and i dip the clutch till the revs drop they drop right out this is doing my head in, can anyone help? Edited March 6, 2008 by rapidmi Share this post Link to post Share on other sites
rallyeluke 0 Posted March 6, 2008 ecu temp sensor is probably the culprit. Share this post Link to post Share on other sites
rapidmi 4 Posted March 6, 2008 (edited) its does it regardless of temp, is the temp sensor in the ecu? if it is it cant be that ive already changed the ecu and the problem persists Edited March 6, 2008 by rapidmi Share this post Link to post Share on other sites
BamBamGTI 0 Posted April 8, 2008 Is it when the car is cold or all the time? Mine used to do this when cold, turned out to be a sticky cold start valve not letting enough air through. Worth a check Share this post Link to post Share on other sites
Tom Fenton 1,548 Posted April 8, 2008 Try removing the throttle body, remove the idle speed screw, and then give the passageways a really good clean out with some carb cleaner. Worked well on my car. Share this post Link to post Share on other sites
Rob_the_Sparky 10 Posted April 8, 2008 Did it start doing this on its own, was it once OK, did it after some work carried out? An air leak can also cause symptoms like this, commonly the bolt that holds the oil filler on as the drilling goes straight throught the manifold so leaving this out results in a significant air leak that is very hard to find. Rob Share this post Link to post Share on other sites
Ethos 0 Posted April 10, 2008 Mine did this, seems to of stopped doing it since I played with ignition timing and idle speed (idles at just over 1k when fully warmed up now). Share this post Link to post Share on other sites
jeremy 71 Posted April 12, 2008 Check all the wiring, to make sure it is not moving in the bay when the car is slowing down and shorting on the engine/bodywork. Does the rev counter suddenly drop, as if so this could well be the case as had this on my 1.6. It was an easy fix of insulation tape near the top enginge mount. Share this post Link to post Share on other sites
andrewhewitt 3 Posted April 14, 2008 Is it when the car is cold or all the time? Mine used to do this when cold, turned out to be a sticky cold start valve not letting enough air through. Worth a check where is this valve situated? Share this post Link to post Share on other sites
