duncs
1.6 Beam To 1.9 Beam
duncs
iv a 1.6 shell running a 1.6 beam but iv had a re built 309 beam lying and would like to swap them over what do i need to complete the swap??
tools and handbrake cables :blink:
possibly some brake pipe fittings IIRC
Edited by welshpug
duncs
so i can use the 1.6 master cylinder with no problems?
John_205_GTi
I've been told that you can, i'm going through the same process at the minute.
Ryan
I've kept the 1.6 setup (master cylinder, compensator, and pipework) and it's been fine.
All you really need for the swap is a pair of 1.9 handbrake cables, and the pipework between the rear calipers and the the rubber hoses round the beam - the 1.6 has hard pipes that go straight into the drums, the 1.9 and 309 have a rubber hose going into the caliper.
You might also need to trim off the inner lip on the plastic arch trim if the tyre rubs.
