duncs 0 Posted March 6, 2008 as above really iv a set of goodwood leather seats from a 309 to put into my 205 iv had a quick look and the fixings on the back seats look different and im not wanting to bodge it as my kids child seat will be strapped to it as well, anyone done this to there 205 before? cheers in advance Share this post Link to post Share on other sites
tidypug 5 2 Cars Posted March 6, 2008 (edited) type "405 seats" into the search menue and you'll get loads of info for you Edited March 6, 2008 by tidypug Share this post Link to post Share on other sites
205turbo 32 2 Cars Posted March 6, 2008 (edited) back seats are basicly the same and will fit in if you use the 205 mounting brackets on the bottom, you need to remove a cover on the uprights on the mounting bracket only, The fronts will require 205 subframes and a 50mm space "3mm steel" and 4 m8 nuts and bolts m8x25mm cheers paul Edited March 6, 2008 by 205turbo Share this post Link to post Share on other sites
Ryan 99 Posted March 6, 2008 The rears are the same size as the 205 rears, so they will go straight in if you swap the brackets over. The front seats are slightly wider, but will fit. The easiest way is to use the 205 seat rails - bolt the inner edge of the rails (side nearest the handbrake) straight to the seat, and then use a couple of short strips of metal on the outside edge (nearest the door) to make up the distance between the rail and the holes in the seat. Share this post Link to post Share on other sites
jeremy 71 Posted March 14, 2008 HTH http://forum.205gtidrivers.com/index.php?s...mp;hl=309+seats Jeremy Share this post Link to post Share on other sites
