kaich 6 1 Cars Posted March 6, 2008 (edited) I need to know if I can put this xu9j4 bits in my 1.9 8v: A - AFM B - coil C - ignition AMP D - ECU (nr 125) Thanks Kaich Edited March 6, 2008 by kaich Share this post Link to post Share on other sites
GLPoomobile 958 Posted March 6, 2008 A - AFM - no B - coil - yes C - ignition AMP - yes D - ECU (nr 125) - no Share this post Link to post Share on other sites
ORB 227 1 Cars Posted March 6, 2008 Why would you do that? Share this post Link to post Share on other sites
Miles 331 1 Cars Posted March 6, 2008 If your running Motronic on your 8v then the AFM is the same Share this post Link to post Share on other sites
cybernck 403 1 Cars Posted March 7, 2008 ^ i was just about to say the same thing . Share this post Link to post Share on other sites
GLPoomobile 958 Posted March 7, 2008 surely the fueling will be wrong though won't it? I mean I know you can adjust that by moving the cog inside to alter the spring tension, but as is I would have thought a late motronic 8v would have a different set up on it's AFM to an MI. Share this post Link to post Share on other sites
cybernck 403 1 Cars Posted March 7, 2008 not really, AFM in Motronic setup just tells the ECU what's the engine load while the fueling is mapped in the ECU . Share this post Link to post Share on other sites
kaich 6 1 Cars Posted March 7, 2008 as I imagined thanks for replies! no, I haven't got a Motronic in my 205, a I have L-tronic I have got a lot of second hand bits of mi16, so why don't put them in my 8v? the output resistance of mi16 AFM is different fro 1.9 AFM (I tried with a tester) OT difference between 2 row e 3row ecu? and what about row? Share this post Link to post Share on other sites
cybernck 403 1 Cars Posted March 7, 2008 well between Motronic and Jetronic, AFM's ARE different. but Motronic 1.9 and 1.9 16v are the same (number 02802202 or something like that). Share this post Link to post Share on other sites
steve@cornwall 100 Posted March 7, 2008 well between Motronic and Jetronic, AFM's ARE different. but Motronic 1.9 and 1.9 16v are the same (number 02802202 or something like that). So the 1.9i ZX and 405sri recently crushed at a local breakers......... I let 2 Mi16 type afms get crushed? tell me not Share this post Link to post Share on other sites
