Rob Turbo
Turbo'd 1.4?
Rob Turbo
When I put the 2.0 turbo in my 306 I pulled out the 1.4 tu engine and left it sitting outside the shed (since December) I've been thinking about having a play with it just out of boredom really!
At first I was just going to pull it to bits, clean it up, then put it back together with new gaskets and seals, possibly do a bit of porting and polishing just as a bit of practice, then sell it to my mate cheap because he has a plan to buy a cheap car and tart it up, just for something to do!! (you can probably guess that there's not a lot to do in county durham)
But now he's started talking about getting a banger, turboing it then having a bit of fun until it breaks! The engine in question is a TU3MCZ (KDX), which is a 75bhp single point injection engine, the plan is basically strip the engine, clean it up, port and polish, bodge a turbo (probably a t2) onto the exhaust manifold, about 6psi boost and a rover 800 intercooler, the turbo and intercooler we already have, so other than gaskets and an oil feed pipe it will be costing nothing!
The thing is, fueling, would a cossie fpr sort things out (as used on the 1.6 turbo on the main website, will increase fuel pressure as the boost increases)
We're not trying to build a skyline eater or anything like that, just messing around! Has anyone tried/heard of anything like this and if so, what happened?
Sandy
Could be a laugh!
axnutty
Ive seen a R5GTT carb sitting ontop of a very slightly modded TU carb inlet before now. Think GTT carbs are about £25 on ebay.. so hardly breaks the bank and mods required are very limited.
The AX inlet mani will bolt striaght onto the SPi Tu head as well... so there you go :( Cheap turbo conversion.
