colti 5 Posted March 4, 2008 Hello guys, Does anyone know if the rev counter ecu output(pin43),on the early xm need modding to drive the 205 clocks? Have not been looking forward to sorting the wiring! Thanks Share this post Link to post Share on other sites
bales 1 Posted March 4, 2008 I take it the xm engine is the xu10cjte, in which case you need to modify the tacho regardless of the ecu, you can't just plug it in, there is a small circuit you need to make from the coil pack to the tacho which is well documented on this forum. Though be careful as there are a number of circuits shown on here and not all of them work, in fact I broke one tacho by following a circuit on here, so dont just blindly connect it up and start your engine up! Share this post Link to post Share on other sites
welshpug 1,675 Posted March 4, 2008 Or PM Spiky for an adapter so you dont have to take your dash apart, unless you want to make it yourself Share this post Link to post Share on other sites
colti 5 Posted March 4, 2008 I take it the xm engine is the xu10cjte, in which case you need to modify the tacho regardless of the ecu, you can't just plug it in, there is a small circuit you need to make from the coil pack to the tacho which is well documented on this forum. Though be careful as there are a number of circuits shown on here and not all of them work, in fact I broke one tacho by following a circuit on here, so dont just blindly connect it up and start your engine up! Oops,that could have been nasty!! I'm not doing the conversion from scratch,just tidying up someone elses mess.(By an alledged 205 specialist!) The rev counter was previously driven by one of the said adaptor circuits.(Two wires from the switched circuits of the coil pack) Having found the tacho output from the ECU,didnt think this was necessary. Guess i'll put the little box back on then!!! Ta guys Share this post Link to post Share on other sites
Spiky 37 Posted March 8, 2008 i just made a loom for the 8v turbo for someone else if it works(dont see why it wont) i will start selling these as i do the gti-6 looms keep and eye on the following post http://forum.205gtidrivers.com/index.php?s...80&start=80 cheers welshpug for the plug Share this post Link to post Share on other sites
craig f90 0 Posted March 12, 2008 i just made a loom for the 8v turbo for someone else if it works(dont see why it wont) i will start selling these as i do the gti-6 looms keep and eye on the following post http://forum.205gtidrivers.com/index.php?s...80&start=80 cheers welshpug for the plug I think its me Spiky's writing about, ive greatfully recived it, Cheers. A very tidy looking bit of kit. Im just searching now if i connect 4 wires or 2 from the converter. Im sure its 2 between the ingition module and coil- pin 1 and pin6. On the 2.0 8v's. Spiky if you read this, how many of the 4 wires have diodes? please. Im confusing myself here, but i miss my rev counter. Share this post Link to post Share on other sites
welshpug 1,675 Posted March 12, 2008 yep, goes on the two signal wires from the amp to the coil, one to earth and the other to the tacho I cable tied mine up next to the amp as it all sits in a 35mm film canister. Share this post Link to post Share on other sites
Spiky 37 Posted March 12, 2008 as per welshpug, all wires have a componet on them but they different they all labelled up so should be ok Share this post Link to post Share on other sites
craig f90 0 Posted March 13, 2008 Ace Ill try it out on the weekend. I cant wait. Thanks guys. Share this post Link to post Share on other sites
