brianthemagical
Flywheels.
brianthemagical
I'm after a flywheel for an MS conversion, but i don't want the weight of a STD Mi, as mine is lightened already, or the cost of binning my 4000mile clutch. It's for a xu9ja, currently with STD lightened flywheel. After a bit of searching, it looks like the XU7 flywheel may fit the bill. So, any specifically that are better, any ideas on there weight, i take they will fit straight on and work off the STD VR sensor? I think thats about it for now. Any help appreciated please. Thanks very much for any help.
200mm flywheels with 60-2 teeth on them are easy enough to get hold of, but they're not particularly light as standard.
Pretty much any XU5/XU7/XU9 8v and XU7 16v engine with Motronic/Magneti-Marelli management will have one.
XU9 16v (Mi16) and all 2.0 8v and 16v engines have a larger 215mm flywheel.
brianthemagical
Thanks for the help. Any idea on approximate weights, or where i might find them? Are the above flywheels differnt to each other? i had a search on pug 306 but that didn't help too much. I might just have to get one and see. thanks again.
