brianthemagical 1 Posted March 3, 2008 I'm after a flywheel for an MS conversion, but i don't want the weight of a STD Mi, as mine is lightened already, or the cost of binning my 4000mile clutch. It's for a xu9ja, currently with STD lightened flywheel. After a bit of searching, it looks like the XU7 flywheel may fit the bill. So, any specifically that are better, any ideas on there weight, i take they will fit straight on and work off the STD VR sensor? I think thats about it for now. Any help appreciated please. Thanks very much for any help. Share this post Link to post Share on other sites
Anthony 1,003 Posted March 3, 2008 200mm flywheels with 60-2 teeth on them are easy enough to get hold of, but they're not particularly light as standard. Pretty much any XU5/XU7/XU9 8v and XU7 16v engine with Motronic/Magneti-Marelli management will have one. XU9 16v (Mi16) and all 2.0 8v and 16v engines have a larger 215mm flywheel. Share this post Link to post Share on other sites
brianthemagical 1 Posted March 4, 2008 Thanks for the help. Any idea on approximate weights, or where i might find them? Are the above flywheels differnt to each other? i had a search on pug 306 but that didn't help too much. I might just have to get one and see. thanks again. Share this post Link to post Share on other sites
