d-9
Top Mount Bearings
d-9
Anyone got the part no's to get the top mount bearings seperatly from pug? I went in and asked for some from a berlingo, but theyre about 1/2 the size they should be :D
Super Josh
Doug, I thought that asking for the Berlingo ones was how you got the correct ones from GSF? As they don't list any for the 205.
Josh
205 top mount bearings aren't listed separately on servicebox, only as a complete spring pan bearing buffer top plate and nuts
5031 25 MOUNTING ASSY 42.49 GBP 49.93 GBP
oddly they are listed separately for every other pug! 106, 206 306 405 and even the 207 and 307 all use;
503527 THRUST BEARING 18.71 GBP 21.98 GBP
which is cheaper than a Lemforder bearing from Euro Car Parts, GSF do list a top mount for the 205.
Edited by welshpug
Super Josh
Yeah they do. But I thought for people who just wanted to replace only the bearing, they ordered the Berlingo?
Josh
ZX/Berlingo ones from GSF are correct for definate, as that's what I've always bought. I'll double check the part number I've ordered in the past tonight if needs be.
However, there's a dodgy batch or more than one variety in their stock system somewhere, as I know Kate ordered some bearings a while back for her and Ash, and got two correct ones and two of the smaller ones you mention.... all on the same part number if I recall :D
mossy
eurocarparts.com
Have them listed
10 quid ish inc VAT
d-9
This was pug that sold me the wrong ones, theyre about 2.5" in diameter. Any ideas if pug do them sepeartly as Ive had bad experiences with aftermarket bearings before?
yes
d-9
Ahh nice one, cheers :wacko:
they should be the right ones, as they're fitted to nearly every pug out there :)
hodgy
what diameter should the 205 ones be as ive ordered some from gsf and now im worried there the wrong ones!
Approx 100mm where it fits into the top cap & 70mm for the bit that sits in the top spring pan.
Graham.
