M_R_205
Drivers Side Brake Not Releasing.....
M_R_205
So, my front divers side calliper wont release, now, just before christmass i rebuilt both front calipers, new seals and new pistons, and i can easily push the piston back into the housing, so question is if my marster cylinder is buggered, could it be leaving some residual pressure behind???
Cheers in advance
Paul
nick
Have you still got rubber hoses? If you have these can split inside and the rubber acts like a one way valve. A good test is to park on a hill and press the brake, when you release it it will probably stay still for a while and then slowly roll back as the pressure drains from the caliper.
Nick
base-1
Same thing can happen if the hard brake pipes have been squashed somewhere
M_R_205
Iv curently got braided lines and theres no kinks or squashed sections, the presure dosnt seem to go awayfor the 5 - 10 mins i had the car jacked up the wheel wouldnt release...
Jrod
I had alot of problems with this when I first had a 205. I changed the calipers, flexis and solid lines and it was still there. Wasn't until I changed the MC it went.
