bluespanner 0 Posted February 27, 2008 Will it lessen understeer or make it worse? Its going down 55 at the front. Cheers:) Share this post Link to post Share on other sites
Jrod 7 Posted February 27, 2008 Depends what you do to the rear, 55 sounds too much though. Share this post Link to post Share on other sites
bluespanner 0 Posted February 27, 2008 Dont worry about the height - its a DTurbo and sits up at the front. 55mm wont even take the tops of the tyres level with the arches... Share this post Link to post Share on other sites
NeilGTi85 5 Posted February 28, 2008 On my MI it was set up by spooks at 55 at the front and 65 at the rear.....seriously low....too low. It constantly rubs on the rear arche's when cornering over bumpy roads etc... The front seem's fine, but very stiff. I would say aslong as you dont come close to the arch you'll be ok (if you can stand the bumpy ride) On the understeer side of things.....im not sure, I had a original 1.6 GTi and that understeered like a **** (standard 1.6 alloys), on my MI i have 405 wheels which are wider etc...and there is hardly any understeer in the dry.....but then you could get some decent tyre's which do make a massive diffrence e.g top end toyo's Neil Share this post Link to post Share on other sites
Stu 18 Posted February 28, 2008 My otherwise standard 1.9 GTI had been dropped something stupid like 65mm at the front before i bought it, with the rear adjusted to suit. It understeered, oversteered, did everything bar get round a bend without any drama. I think the key is what you do to everything else, ive just finished putting it back together, its now got 309 front running gear, bilsteins, -40mm springs, and grp n top mounts. The back end is stock, but i intend to move over to 309 beam at some point to compliment the stiffer front springs. Id defo get it tracked up afterwards fella, are you going to lower the rear beam too? Share this post Link to post Share on other sites
McDude 33 Posted February 29, 2008 The act of lowering a car won't have a massive effect either way - for a given spring/damper setting it will produce less body roll, therefore less weight transfer and perhaps less oversteer in the dry as it, but maybe more in the wet. It is the fact that you are stiffening up the springs/dampers at the same time. Too stiff and you will just understeer everywhere (no weight transfer) especially in greasy conditions. But a little bit stiffer would help you in the dry - especially if you are putting on wider profile tyres as this will load up the suspension more than the stock skinnys. There are a lot of variables to consider, Stu Da Rude is right - it depends on what you do to everything else. Share this post Link to post Share on other sites
bluespanner 0 Posted March 3, 2008 My otherwise standard 1.9 GTI had been dropped something stupid like 65mm at the front before i bought it, with the rear adjusted to suit. It understeered, oversteered, did everything bar get round a bend without any drama. I think the key is what you do to everything else, ive just finished putting it back together, its now got 309 front running gear, bilsteins, -40mm springs, and grp n top mounts. The back end is stock, but i intend to move over to 309 beam at some point to compliment the stiffer front springs. Id defo get it tracked up afterwards fella, are you going to lower the rear beam too? Well from the top of the rear wheel to the arch is 45mm. (on 195/50R15s) From the top of the front tyre to the arch is a whopping 100mm, which is why I went for the 55mm drop, to try and get things level. 100-55=45 When budget allows, I'll get some good quality shocks all round. I know its not great to use standard shocks, but I'll get better when I have saved up again. Share this post Link to post Share on other sites
nick 3 Posted March 3, 2008 When you lower it you automatically get a bit more negative camber which will help a bit. Nick Share this post Link to post Share on other sites
brianthemagical 1 Posted March 3, 2008 When you lower it you automatically get a bit more negative camber which will help a bit. Nick but your further in to the camber curve and it'll start positiveising after the wishbone is level. Share this post Link to post Share on other sites
