skanny
Rear Beam Stud Info Required
skanny
Im looking to find out what diameter the studs are on the rear most beam mounting rubbers and the thread too if possble ie M8 etc...
And if at all possible if anyone can measure the overall length from the tip of one of the threaded studs to the tip of the other on the rear mounting rubber.
I have re fitted my beam now and should have measured it when it eas off the car!
The stud thread is M10 x 1.5 & the stud through the beam is approx 16mm long where the stud which comes through into the boot floor has the same length of thread but is 32mm long in total.
Graham.
