tjcgti 0 Posted February 25, 2008 Hello this is my first pug 205 and dont know alot about there characteristics, but when i push my clutch it needs to be pressed all the way to the bottom to get a gear change and is quite stiff. Just wondering if this is normal in pugs or not. Cheerz Share this post Link to post Share on other sites
jord294 94 Posted February 25, 2008 it may just need some adjustment. has the car been stood a long time with out being driven? Share this post Link to post Share on other sites
jord294 94 Posted February 25, 2008 personally then, if i were going to use a car that had been stood a long time, i would change cambelt, clutch, all fluids and filters and just give everything else a once, maybe twice over what car have you got? Share this post Link to post Share on other sites
tjcgti 0 Posted February 25, 2008 it a pug 205 gti 1.6. it had been standing for a while but not too long. i have replaced the oil filter, fuel filter and air filter, cleaned the spark plugs and gapped them, changed the oil and put engine cleaner into it. seems to run much better now as engine was racing a bit but now ok. think the cable might just need adjusting. Share this post Link to post Share on other sites
smokey 0 Posted February 25, 2008 I asked a similar question when i first got my CTI. Your Clutch cable might have ceased up, you can get a replacement for not too much from GSF. Share this post Link to post Share on other sites
tjcgti 0 Posted February 26, 2008 kk will have a look cheerz Share this post Link to post Share on other sites
djinuk 2 Posted February 26, 2008 just adjust it via the two nuts on the end that sits underneath the battery tray, there is a good chance its fine Share this post Link to post Share on other sites
Phil205 1 1 Cars Posted February 26, 2008 Hello this is my first pug 205 and dont know alot about there characteristics, but when i push my clutch it needs to be pressed all the way to the bottom to get a gear change and is quite stiff. Just wondering if this is normal in pugs or not.Cheerz I had exactly the same thing with mine. The clutch cable tends to stretch with time or use. Adjust the clutch pedal position by tightening the nut on the end of the cable. A few turns will do. Loosen the lock nut before adjusting then retighten the lock nut in the new position. Takes about 5 minutes to adjust once you have two spanners of the right size. You will feel the difference when you press the clutch pedal with your foot. Share this post Link to post Share on other sites
