Dan Ingram
Twin 40s
Dan Ingram
Will twin 40s be big enough for a 2litre iron block mi or will 45s be needed?
Can of worms...
Different trains of thought here but personally they should be fine with 36mm chokes. But some will say otherwise.
Edited by BazGTMi
Hilgie
I'd say you have to go with 45ers. 40ers will be fine on an 8V though.
danpug
I mentioned this a while back but nobody responded, people put 45's on an mi16 (for example) and choke them down to 36mm but everybody says you shouldn't use 40's even though you could put 36mm chokes in them? What is the difference? Surely its all down to choke size.
rapidmi
45's all the way mate, you wont regret it till you realise that you need to toe a petol tank about with you haha
