mainline
Gearbox Oil
mainline
The search kept throwing up too many results and I couldn't find what I needed, which is quite simply, which gearbox oil should I use to top up / replace the stuff that's in there now. Quite a lot of it has spilled out when changing the driveshaft and replacing both wishbones.
Many thanks
Ian
75W80 - I personally use Total BV stuff that seems to work well (and is cheap from the likes of GSF)
