205007 12 Posted February 19, 2008 (edited) im refurbing a 309 gti axle and my usual method of removing the inner bearings with a scaffold tube is not working it looks like there is a lip inside which the bearings butt up against which shields them from my attack! but im not sure as i cant see it because of the bearing itself this is not present on any 1900 beams i have done can anyone shed some light on how to knock them out? thanks adam Edited February 19, 2008 by 205007 Share this post Link to post Share on other sites
pug_ham 245 3 Cars Posted February 24, 2008 Normally I now use an old radius arm shaft & knock the old inner bearings into the centre of the tube & then use a torsion bar with the offset washer bolted on the end to knock them both back through & out of one side of the tube. I have previously got them out by the old torsion bar & offset washer method from the opposite side knocking them out rather then into the middle. Graham. Share this post Link to post Share on other sites
Anthony 1,003 Posted February 24, 2008 Bash them out with an old trailing arm shaft (bigger end first) and BFO hammer - never failed me yet Share this post Link to post Share on other sites
stutto 0 Posted February 25, 2008 But is Adam right? Is there a lip in 309 beams or are they just reluctant to move? I am now at the same stage myself, used an old trailing arm and 4lb hammer to (try to) hit them inwards - no movement. Is it just time to get the 7lb out? Share this post Link to post Share on other sites
daza4 24 Posted February 25, 2008 I used a small screwdriver and tapped the inner bearings towards the centre of the tube and then used a big bar to drop them out the other end. Much easier then using a long bar to knock them out the right way!!!! I am sorry I dont know if there is a lip or not. Could just be stuck!! Share this post Link to post Share on other sites
Anthony 1,003 Posted February 25, 2008 But is Adam right? Is there a lip in 309 beams or are they just reluctant to move? I am now at the same stage myself, used an old trailing arm and 4lb hammer to (try to) hit them inwards - no movement. I've recon'd more beams than most, and I've never had a problem removing the inner bearings - there's no lip or anything stopping them being knocked out from either direction. They will require a reasonable amount of force to move, but nothing that a few knocks with a lump hammer won't do. Share this post Link to post Share on other sites
pug_ham 245 3 Cars Posted February 26, 2008 But is Adam right? Is there a lip in 309 beams or are they just reluctant to move? I am now at the same stage myself, used an old trailing arm and 4lb hammer to (try to) hit them inwards - no movement. Is it just time to get the 7lb out? I've recon'd more beams than most, and I've never had a problem removing the inner bearings - there's no lip or anything stopping them being knocked out from either direction. They will require a reasonable amount of force to move, but nothing that a few knocks with a lump hammer won't do. I've refurbed a few beams now but like Anthony I've never had any problems removing the inner bearings that a 2lb lump hammer hasn't solved, certainly haven't seen any with a lip on the inside of the tube either. When I first started doing refurbs I used to knock the bearings out from the opposite side but decided it was much easier to knock them into the middle & then knock them out through one side afterwards. Graham. Share this post Link to post Share on other sites
welshpug 1,666 Posted February 26, 2008 I havent done anywhere near as many beams as Anthony and Graham but that's exactly how I do it Share this post Link to post Share on other sites
205007 12 Posted February 26, 2008 its impossible to knock them into the middle of the beam due to the bearings sitting on this lip i did a 1900 beam without issues but this one is different Share this post Link to post Share on other sites
pug_ham 245 3 Cars Posted February 26, 2008 Well the way I used to do it was with an old offset washer on one end of a torsion or anti roll bar & hit the other end to drive them out of the tube. Worked, not the easiest way but if they won't push in any further then worth a try. Graham. Share this post Link to post Share on other sites
205007 12 Posted February 26, 2008 ill give it a whirl tomorrow, if that does not work ill cut it in half and get them out! Share this post Link to post Share on other sites
stutto 0 Posted February 28, 2008 It is just an 'illusion', there is no lip. I used, thick end first as recommended, the old trailing arm and a bit more persuasion and they moved. Then used a TB with two old M8's in to knock both out of one end. Now for paint and rebuild. Cheers folks. Share this post Link to post Share on other sites
