Guest Mary
Knocking When Braking In Reverse?
Guest Mary
Hi Guys,
I have a knocking coming from the front brakes of my K reg 1.6 GTi when I brake after reversing. It only does it when i'm in reverse. Any ideas or advice please?
James_R
that's sort of normal for std 1.6 calipers on the front.
Best way to stop it is to upgrade to 1.9 front calipers and pads on 1.6 discs :blush:
knock comes from the pads moving in the caliper (which i think james means)
j_turnell
As above common trait with 1.6 calipers, not a big issue really.
Either bare it or change them for 1.9 Cals as James says.
cybernck
O/T: this must be one of the oldest questions about 205 GTI on the internet!
i remember it being repetetively and often asked 10+ years ago! :blush:
luckily, there are not so many 1.6's around now :).
Guest Mary
Thanks everyone, i'm a bit clueless at the mo, :blush:
Neither myself or anyone i know have any experience of 205's!
Jrod
I thought it was the sliders wearing which made the knock? :lol:
richsmells
Mine were awful, even worse after fitting new pads and disks. It didn't give my passengers much confidence when I reversed off the drive. I believe it's the sliders wearing, resulting in play in the Bendix caliper. I've had 1.9 girling calipers fitted with the 1.6 disks for a couple of years now with no troubles.
Longun
luckily, there are not so many 1.6's around now :P.
Thats not fair :lol::P Nothing wrong with a 1.6...... Well apart from the calipers.......
James_R
better than 1.9's imo :lol:
kate205gti
my CTI did this a treat :lol: 1.9 engine but feck know what calipers they were
uncle buck
I had the knocking pad problem on a 309 diesel I had a few years back...upon inspection the pads were quite a loose fit in the caliper....I cured the knocking by getting my mate to run a line of MIG weld along the top edge of each pad....I then used a grinder to remove the weld a little at a time until the pads were a nice snug fit in the caliper....sorted no more knocking when braking in reverse :lol:
