shooter mcgavin
How To Get Oil Pressure And Temp Working
shooter mcgavin
what needed to get the oil temp and oil pressure gauges working in my 205 gti6?
i have wired everything up and have water gauge and warning ligths lorking but remember reading something about having to use a converter of some sort
cheers
jonnie205
lights are easy with the gauge you can do a few different ways either machine a boss to run the 8v or find one from a very early gti6 phase 1
shooter mcgavin
my engine came from my phase 1 gti6
you think if i wire them up from the 205 brown plugs under the dash they will work?
do you know what wires they go to from the 19 pin plug
btw cheers for all your help on this build jonnie almost done now
Spiky
i used a 205 pressure sender with adapter in gti6 engine, no point have a low warning, if you see that the engine is probably already dead
Matt Holley
Same here :D
