24seven 104 Posted February 17, 2008 so what kinad spacers are best, and where can I get them? need smoe as I'm planning on fitting Mi16 wheels to my 205. do I want some that bolt to the hub, then the wheels bolt to the spacers? or just huncentric ones. either way, where's the best place to get them, and roughly how much do they cost? Share this post Link to post Share on other sites
welshpug 1,666 Posted February 17, 2008 PM Rippthrough, he made some Hubcentric ones not too long ago and may have some left. if your car is still running 1.6 gear though you may be able to fit them with only 3/4mm spacers as the 1.6 wheels are ET25 (as opposed to 28 or 29) Share this post Link to post Share on other sites
Rippthrough 98 Posted February 17, 2008 (edited) Got a set of alloy 13mm ones left if they'll do you - might bring you a bit too far but you'd have to double check the length of your hub lips are below 10mm as they aren't always with non-oem discs/drums, means the offset can be wrong too though - best to check from the back of the hub for offset spacing. 10mm hubcentric require the lip grinding down slightly. Edited February 17, 2008 by Rippthrough Share this post Link to post Share on other sites
24seven 104 Posted February 18, 2008 thanks for the advice. the car should be all 1.6 (except the engine) underneath unless it's had a sneaky change over by a previous owner. rippthrough, is that a set of 2 or 4? how much do you want for them? if needed I can get them turned down a little locally. Share this post Link to post Share on other sites
Rippthrough 98 Posted February 18, 2008 I can do you a set of 4 for £70 if you want them. Share this post Link to post Share on other sites
