Spiky
Gear Linkage Bushes
Spiky
mine are a bit warn
should i replace them with pug one's? or is there a better alternative????
also does anyone have a spare "L" links part as i want t modify it to make it a quick shift, as i want to keep mine just in case i dont like it ;)
pug ones are sooo damn cheap its daft not to,
245027 SHAFT SOCKET 0.36 GBP
217505 SHAFT SLEEVE 0.23 GBP
you need 2 of each.
any alternative is around the £20+mark
Spiky
ah, fooking sweet dude
have you got a pug parts program then??? as you seem to have all the part numbers..lol
everyone can have it mate, check my sig ;)
they're common to nearly all pugs as it happens, ok they're nylon but for how long they last and how cheap they are I don't think its worth spending more :P
gear linkages are a different matter I think, I want to go metal on them.
Spiky
i have a set of miles rods,
cool, will order a set tomorrow
so i just need to create an account on the service site then?
yup, its free to obtain most areas of the site.
Spiky
cool
cheers
If your handy with a lathe or know someone who is you can mod the 306 bushes as these are 100% better in design, I will be getting some made up soon
you've confused me now miles, one of the two part numbers mentioned above are for the 306 as well?!
oli-pug
Does anyone know if the standard bushes fit constella linkages. The kit i bought a few years back didnt come with any sort of bush, you just secure the ball end in with a clip. Is this why they're so damn noisy!?
If your on about the ball cup's then no but I know what you mean as it's only the retaining clip that holds them on, But any uprated part will transmit the noise more, You can grease them up which helps but I found them a mare to fit when I encounted them the other week as they kept falling off when I was putting the pin in
With the 306 bushes you need to machine them done along with the coller inside and you get a nice pivit point unlike the std 205 ones
oli-pug
Ok I'll try a touch of grease in them. Yeh, they are a real bloody nightmare to fit! :)
