shooter mcgavin
Which Top Hose 205-6
shooter mcgavin
i cut the bend off the 205 top hose tonight and shortened the gti6 1 ,now i have 1 hose that fits to the rad only problem is its in the way of the airfilter pipe now
cant juat change the hole hose since the 306 hose has a fancy end where it meets the stat housing
is there a better way of doing this
oh and i am not running the heat exchanger
Alastairh
When i done mine i used a few 90 degree bends and routed the hose under the air filter pipe and upto the rad in its standard location.
Hopefully i will be doing another conversion for myself some time soon and will run one of Pauls converters, i suspect the standard will have to run above the filter pipe though.
Al
shooter mcgavin
think i will use a few bends for now
what did you use to sleeve them together
