notamondayfan 44 Posted February 12, 2008 hey guys, im trying to order parts from GSF, but they need the engine code, which i dont know. i have a code from the block - 1CW5D003047. i know very little of the engine, just that its a 1.9 mi16. i found this on another thread, but dont know which one. maybe someone does? 405 1.9 Mi16 & 4x4 16v XU9J4K (D6C) 1988 - 1991 Motronic ML4.1 405 1.9 Mi16 & 4x4 16v XU9J4K (D6C) 1991 - 1993 Motronic M1.3 405 1.9 Mi16 cat XU9J4/Z (DFW) 1990 - 1992 Motronic M1.3 desperately need help! cheers, dean Share this post Link to post Share on other sites
notamondayfan 44 Posted February 12, 2008 (edited) also printed on the head is 2FB SIMI 328912 9153818780 141089 is the last set of numbers the date of production? ie 14/10/1989? cheers, dean Edited February 12, 2008 by notamondayfan Share this post Link to post Share on other sites
welshpug 1,666 Posted February 12, 2008 what parts are you trying to source? Share this post Link to post Share on other sites
notamondayfan 44 Posted February 12, 2008 clutch kit, timing belt and tensioners, exhaust gasket, pas belt, alternator belt, water pump, clutch release fork bearings, cheers, dean Share this post Link to post Share on other sites
welshpug 1,666 Posted February 12, 2008 clutch kit, timing belt kit, w-pump exhaust gasket and clutch release fork bearings are all the same regardless of the age of the lump as far as I know. pas+alt belt depend on where the pas pump is mounted. D6C and DFW are the codes most commonly used by the way, or XU9J4, the list you pasted above show which management used on each version, do you know if yours is running its original management and which one it is? (check the code on the ecu) Share this post Link to post Share on other sites
Anthony 1,003 Posted February 12, 2008 It'll be an XU9J4 engine if it's a 1.9 Mi16 non-CAT, with the engine code D6C For most of the bits, you're better off ordering stating it's for a BX 16v as they were only ever available as a 1.9 16v - GSF have a nasty habit of supplying 2.0 Mi16 parts otherwise if you order saying it's for a 405 (in my experience anyway) Share this post Link to post Share on other sites
Emmy Seize 8 Posted February 12, 2008 (edited) D6C = without catalytic converter 158 PS DFW = with catalytic converter 147 PS As already asked, it depends on the parts you want to order whether the code makes any diference at all. Hmm- should improve my typing-speed... Edited February 12, 2008 by Emmy Seize Share this post Link to post Share on other sites
notamondayfan 44 Posted February 12, 2008 cheers guys! ill try again! 3rd time lucky!! Share this post Link to post Share on other sites
pugman211 0 Posted February 16, 2008 the DFW engine has a Lambda sensor on it, so look for one of those on the exhaust system. If there isnt one, its more likely to be the D6C. Share this post Link to post Share on other sites
