205freak 7 1 Cars Posted February 10, 2008 Hi, i want to rebuild my beam but at the same time, want wide track , it´s a 1.6 beam with disc conversion. What´s the best set up??? Cheers. Share this post Link to post Share on other sites
Batfink 201 Posted February 11, 2008 the best setup would be a longer stub axle and a spacer before the hub and bearings but stuff like that would need to be custom. Get a 309 rear beam and flog the 1.6 one Share this post Link to post Share on other sites
205freak 7 1 Cars Posted February 13, 2008 Thanks for you´re reply, but is it possible to use the 306/ZX rear arms on a 1.6 axle, would it be a direct replacement or not???? It´s very difficult/expensive to buy a 309 beam here in Madeira. Share this post Link to post Share on other sites
Anthony 1,003 Posted February 14, 2008 Thanks for you´re reply, but is it possible to use the 306/ZX rear arms on a 1.6 axle, would it be a direct replacement or not???? They'll fit straight on, but they won't give you more track width of note, only increased negative camber Share this post Link to post Share on other sites
