marsy
Brake Pipe Problem
marsy
Im currantly changing all the brake pipes on my 205, and im having a nightmare of a job putting the one's on that go up behind the fuel tanks.
I cant see how i can get the pipe through behind the tanks and onto the connectors.
I had all the pipes and connections cut and done in my local shop, is that my pipes have got the connectors on it the reason i cant do it?
Is there an alternative to running the pipes behind the tanks lol?
Thanks guys. I was going to take it to the garage to have them done, but thought i'll give it ago myself for a change lol.
just drop the tank a little, its only 2 nuts.
stutto
I agree, could not even unclip the old lines from mine without dropping the tank. Syphon as much juice out as possible first, I used a nitrile glove and a rubber band to prevent what was left from evapourating.
Simes
It's easier if you remove the tank so remove also the
spare wheel
exhaust
slacken hand brake cables
disconnect the fuel lines and filler pipe
joe1joe
as said its eaiser to remove the tank but u have to lower the exhaust aswell, and the heat sheild and the hand brake cables, u could remove some of the fuel by removing the feed to the engine and just power the pump or spill it all over the garge floor like i did :unsure: just make sure if the leave fuel in there that u have some one with u as u need to make sure u drop the passengers side of the tank first!
dani959
I didn't move the tank when I did mine... It would just be too much hassle!
I got them in going front to back with a little patience!
Tape the end of the pipes so you don't get any gunk in them...
Good luck!
marsy
Thanks guys, il give it another go on the weekend now, iv removed the spare wheel, exhaust and slacken the handbrake cable, and if my patience dos'nt hold, looks like it'll be the tank next then. thanks.
