Guest Tommy
Mi16 Gearbox
Guest Tommy
Hi all
Will mi16 gearbox fit straight to 1600 GTi
5150maxie
  Tommy said:
Hi all
yes it does.but you need to swap the linkage arm for the 205 one.
i think the mi16 box is the best box.
AdamVester
yeah it bolts on i'm doing the conversion myself soon and im sticking with the 1.6 box for now on it. i herd the 1.9 box is the best to go for though as it feels a fair bit quicker than the mi16 one and the mi16 is a mission to fit apparently.
your best bet would be to shuv on the 1.6 and try it out see if you like it once you get bored shuv the 1.9 box on the gearbox's are hardily expensive to buy you can pick them up for under £100.
jonnie205
mi box no harder to fit its just the same as others but swap 1 lever arm
As said very easy and a like for like swap, The 1.9 box is the worst thou.
