205turbo
Megjolt 36-1 Trigger Wheel
205turbo
I've bought a megajolt to control the ing on my 2045cc on 45's
what size crank trigger wheel are other members using.
cheers
Paul
doesn't matter how big the ring is as long as it has the appropriate tooth arrangement, most use a ring that's slightly bigger than the original crank pulley, which IIRC would mean a 5"3/4 wheel :D
hope that helps :huh:
BTW, does your megajolt not have the capability for 60-2?
Megajolt is 36-1 EDIS only.
I suspect you're thinking of Megasquirt, which has 60-2 capability on all v3 and modified v2.2 boards.
205turbo
thanks for the infomation
cheers
Paul
