damo 17 2 Cars Posted February 6, 2008 can u run a pas pump from a mi16 setup on a 8v 1.9 engine? needs to run from the cambelt i think? i have the rack and pipes etc for a mi16 205 pas conversion, off ebay so the racks the same etc, just thing the pas pump will be an issue. any help , pointers welcome Share this post Link to post Share on other sites
pug_ham 244 3 Cars Posted February 7, 2008 If it would fit (not sure about the pulley alignment) you'll need the plate for the PAS pump / alternator bracket on the front of your 8v engine, a longer alternator drivebelt to run it & a hose that reaches from the front of the engine round to the rack. Graham. Share this post Link to post Share on other sites
yeti-dj 7 Posted February 7, 2008 Hello, the pump you have bought is from a 205 Dturbo if its the parts that just ended on ebay last night? Dont think the pump will be any use to you at all as the pump is driven from the end of the cam shaft thats spare on the MI16 or the diesel but you will have a distributor on the end of your cam. You will need to get the correct PAS pump for the 205 and fit it below the altenator, you will also need the mounting plate i'm affraid. I may be corrected but the set up you have just bought is all good apart from the pump and the bracket that mounts on top of the gearbox. There are loads of people on here who have converted to MI16 so getting the parts you need shouldnt be too hard.. Hope this helps.... Share this post Link to post Share on other sites
