Guest si-gti Posted February 6, 2008 Car has been losing a lot of oil recently, just found an oil leak underneath the distributor cap and there was fresh oil coming out, do i need to replace the distributor or is it just the seal? Share this post Link to post Share on other sites
Rob_the_Sparky 9 Posted February 6, 2008 The seal between distributer and head commonly fails and I guess there is one in the dizzy but never seen enough oil in there to be of real concern. Givent he cost of a dizzy I'd not replace it unless I had to. The odd spot of oil in the dizzy is not unusual and as far as I'm aware causes no problems. Share this post Link to post Share on other sites
Fast Road Jay 0 Posted February 6, 2008 my 1.6 gti was doing this a lot and it used to drip from the vacuum advance valve as it run down the dizzy, i cured it by taking the dizzy off and siliconeing it to the head - leak stopped and didnt cost a penny, bought a spare dizzy and seal since then but being as it hasnt leaked since (been done for over a month) i havent fitted it! Share this post Link to post Share on other sites
richsmells 2 Posted February 6, 2008 The distributor seal hardens up over time and becomes less malleable. Cut the old one off and fit a nice fresh one (about 50p). Mine was leaking quite badly and a new seal cured it. Share this post Link to post Share on other sites
damo 17 2 Cars Posted February 9, 2008 i had a similar issue. mark the dissy location on the engine, un screw and replace its seal / gasket ring and pop it back on. Quick job and cost less then a pound this worked for me, but i need to tweak my timing i think. Share this post Link to post Share on other sites
daza 0 Posted June 28, 2008 (edited) I have just changed the dizzy seal again but the old one lasted about a month,that can't be right? What would cause it to go so quickly please? Edit:when i took old one off the outside of the seal had little bits hanging off it. Edited June 28, 2008 by daza Share this post Link to post Share on other sites
daza 0 Posted June 29, 2008 (edited) I will take a photo of the old seal(between head and distributor) if i find it but what can cause the seal to be frayed round the outside of it? Edited June 29, 2008 by daza Share this post Link to post Share on other sites
