sussex_gti 0 Posted February 6, 2008 I've nearly finished my mi16 conversion, with all the donor parts taken from a bx 16v. Ive done all the sensor wiring, and also the starter wiring. I connected up the switched live wire for the coil power, if im right this goes to the white plug next to the ignition amp plug? This has given me power at the coil, but i have no power at the yellow wire by the ecu for the fuel pump. Although this isnt a problem. The problem i have is no spark at the coil. Could anything else be causing this? Im thinking i may have a dodgy coil. Hope someone can help, would love o be driving this by Saturday! Cheers, Chris. Share this post Link to post Share on other sites
pug_ham 245 3 Cars Posted February 7, 2008 The yellow wire in the white two pin plug should be connected to both the igniton amp (middle pin) & also to the thick white wire at the coil plug internally within the existing loom.(the green wire in that plug is the rev counter signal iirc) The fuel pump relay should have a direct connection to the shunt box Its switched ignition feed is through the same yellow wire above which also runs to the injection relay & has a small green wire which that sends a switched live to the fuel pump relay & then power to the pump. Graham. Share this post Link to post Share on other sites
yorkshirekowboy 19 1 Cars Posted February 7, 2008 pugtorque said: The yellow wire in the white two pin plug should be connected to both the igniton amp (middle pin) & also to the thick white wire at the coil plug internally within the existing loom.(the green wire in that plug is the rev counter signal iirc) The fuel pump relay should have a direct connection to the shunt box Its switched ignition feed is through the same yellow wire above which also runs to the injection relay & has a small green wire which that sends a switched live to the fuel pump relay & then power to the pump. Graham. im having the same problem so would this what uve said be the same of ra 405 mi16 loom? wire colours etc. Share this post Link to post Share on other sites
pug_ham 245 3 Cars Posted February 7, 2008 Wire colours are very likely different on a 405 loom, the BX generally fewer colours through out the loom where the 405 looms have wires most colours. The ignition module has to be earthed to get a spark but iirc it is earthed through a seperate wire back to one of the plugs at the front l/h of the engine bay & not the main loom earth lead on the 405. (it is on my MP3.1 loom anyway). If you are using a link loom maybe you have missed earthing this wire? It still runs from the centre pin of the ignition module so hopefully you'll be able to find it. (Green & yellow wire). Graham. Share this post Link to post Share on other sites
pp205 17 Posted February 7, 2008 I had a similar problem which turned out to be a duff ECU, we had tested every connection on the the loom to the ecu and everything seemed to be fine but still no spark. The engine would turn over and everything - it was so frustrating! We connected an old spark plug to the coil lead and using a power probe on the main ecu power lead (pin 1 on the loom multiplug I think!) got a spark from the coil. Got another ecu from someone on this forum and she started first time! One of the other things to check is the crank sensor as well Share this post Link to post Share on other sites
