skanny
Is This Supposed To Be Like That! Thermo Housing
skanny
Is there something missing from here?
Is there supposed to be a metal pipe pressed into this hole.
I bought the car and there was a small section of tube araldited in and it was weeping badly.
anyone got a picture of what it is supposed to look like?
should be a metal pipe coming out of there with a tee that has a bleed screw in it.
It should look like the picture below but with a bleed screw (preferably a brass one) on the Tee angle just off vertical.
ORB
i would either get another or tap the hole and put a bolt + washer/o-ring in
M_R_205
Bloody cowboys! As orb said, tap it and stick a bolt/washer in there, maybe even a litle silicone if it still leaks.
