smokey
Is There A Difference Between The 1.6 And 1.9 Exhaust?
smokey
Hiya Guys
I was just wondering if there was a difference between the 1.6 and 1.9 gti exhausts?
I'm wondering if my 1.6 exhaust would restrict a 1.9 Mi16?
I've been told i should be ok. My house mate seems to think otherwise.
Ryan
They're the same.
It's probably less restrictive than the 405 exhaust.
not really, the 405 has a larger diameter exhaust than the 205.
Ryan
It is longer though and has more bends in it.
Depends on the year, Phase 1 systems are smaller than phase 2 which are OK to use, The phase 1 (3 piece) is only 1 1/2" bore so not very good at all.
smokey
Thanks for the replys guys
My car is a phase 1 so it sounds like i might have to get a new exhaust too.
Which diameter pipe do i need?
Any suggestions on what to get.
Either an old one of a 1.9 GTI or a brand new one?
I did read that the original exhausts were very good and not to get something too big otherwise that would reduce the power?!
DrSarty
As stated, 1.6 & 1.9 systems the same. I originally ran my Mi engine on the original 1.6 system with no problems whatsoever, less the Mi exhaust manifold to downpipe issue, which I guess you know about.
There should be plenty of half decent, good value 1.6/1.9 second hand systems in the 'for sale' section on this forum.
Rob_the_Sparky
Just take a look at the exhaust behind the rear silancer to identify an early (3 piece) from a later (2 piece). The 3 piece uses a sleeve fit (one pipe over the other) and the later ones use an olive.
Henry 1.9GTi
I have a complete 1.9 exhaust for sale, downpipe with spliter in very good condition, welded to centre section with silencer, then a back box( back box has only done ~7000 miles) which is seperate and clamps on £35 for the lot if your interested. Im in reading as well so not too far to collect. Send me a pm if you would like it :wub:
Cheers.
Henry.
Edited by Henry 1.9GTi
Henry 1.9GTi
Hi smokey, I accidentally clicked delete on your pm instead of reply, clicked back on the browser and sent a msg, but not sure if it went through.
Henry.
