McPikie
Stuck Fast Track Rod Ends
McPikie
Guys, I think some s*it-kicker has put threadlock on mt TRE's :) they will not budge.
Can I take it off at the rack end so I can get it in a vice??
Get some heat into it with a blowtorch.
Dream Weaver
I had this issue, so took it to a local garage instead and paid them £50 to fit the new TRE's, rear bumpstops and something else. They said it even took them a while to get the old TRE's off using heat.
joe1joe
yes you can but its a lot of work as u need to mess around with the inner boot, ur best bet is big blow toarch or oxyacetylene, but not much as your not ment to heat the track rod ends ;)
JayCC
I've got the same problem. Changing my coil springs back to standard. Two bolts snapped on me (hub carrier / strut bolt) and a droplink strut bolt. Sorted this now , went to pug and got new parts.
Now i cant get the TRE to budge (the rubber has perished and all the grease has gone)
Will a blow torch help me budge the 19mm nut?
pete1986
I had this problem on mine recently. I took it to a local garage to get the tracking done and monkey boys there couldnt undo it even with heat, a mate did it in the end with ALOT of effort and various techniques. It came in the end tho. :)
gti-si
Get the steering rack off and put the whole track rod in a vice, get some heat on it and then something with suitable grip/leverage on the TRE to shift it
PhilCTI
I had the same problem when I wanted to put new track rod ends on the power steering rack I was fitting but couldn't get the old ones off.
The rack really needs to be out of the car, and the track rod in a vice.
The way Miles showed me how to do it was to cut the end of the old TRE off with an angle grinder, then you can get a ring spanner to fit round the nut and you get a much better grip on it and with a bit of welly, they normally come off. I suppose once you've cut the end off, you could also then use a socket with a long bar to get some decent leverage on it,
steve@cornwall
I use a big stilson self grip wrench - and a BFH if needed
