Pob
Which Cambelt For My Engine?
Pob
Hi,
I've had a engine swap on my 205, but I'm not sure if its the earlier or later engine... I want to do a cam belt change. Is there any signs? Why does the later type engines have an extra tooth on the belt? Is there differences in the tensioner and finally, is the cam pulley different?
Thanks,
Dan
gti-si
If the coil is located on the inlet manifold it's a later engine
Pob
It doesn't have the coil on the manifold... but the inlet is polished so I think it would of been swapped...
Dan
matty_gti
When you take off your current belt, count how many teeth it has then go down your local motor factors and get one orderd...job done :ph34r:
The coil could of been changed due to the polished inlet but i doubt it. Where abouts if the ign amp?, pass wing, drivers wing?.
Matt
Edited by matty_gti
All 1.6's use the shorter belt (113) and only the late CAT engine's use the 114 tooth belt, you can tell by the type of cam cover fitted or a date stamp post dating 92 on the cam cover
How is the belt tensioned?
If you have a sprung tensioner you need the earlier 113 toothed belt but if its an eccentric roller then you need 114 toothed belt.
Graham.
Pob
Graham.
Hi,
I've had a look and took a picture
Dan
matty_gti
113
Pob
113.
Thanks :D
Dan
