notamondayfan
Pas On Mi16 Conversion?
notamondayfan
hey guys,
still planning the conversion, and this is my current querry.
i have a 1.9gti with PAS, and a 1.9mi engine.
i would idealy like to keep the PAS, as it's a everyday car, but i dont know whats involved in getting it to work with the mi.
what has everyone else done?
cheers, dean
Ryan
The easiest way is to use the Mi16 PAS pump which sits on a bracket on top of the gearbox and is driven by a belt from the end of the exhaust cam. Some diesel 205s have a similar set-up and you can use the pipework from one of these to get everything hooked up. I'm not sure which pipes you need exactly, but I'm sure someone else will.
Super Josh
As you will have spotted the PAS pump is driven of the exhaust cam on the Mi. This is the same as on a 205 Diesel.
So either use the pipework from a 205 Diesel or get a custom pipe made by your local Pirtek type place.
Josh
EDIT
Looks like Ryan beat me to it :ph34r:
Edited by Super Josh
luggy
Im in the process of doing the same thing, I'm led to believe the only mod you need is the high pressure hose from the pump to the rack from a 205 diesel.
Edited by luggy
yeti-dj
Did the same thing on my MI16 and yes you do need to change the high pressure line for the one from the 205 diesel..
will need , pump,mounting bracket,belt and the line, job done....
good luck...
jas-E
Or get an electric power steering set up from a Citreon Saxo (or the 106 i believe...)
notamondayfan
ok thanks. i currently dont have the pump or housing, or an mi gearbox. i was planning to use the gti gear box. can i still mount the pump onto that?
also, are there any other cars the pump and bracket can be found on other than a 405mi?
cheers, dean
M@tt
someone in the for sale section is selling a mi pas setup without the rack iirc ie pump, pipes, reservoir etc
jonnie205
i have an mi pas setup if your interested
Ryan
The mounting holes are on the top of the GTI gearbox as well.
luggy
Fiji bob!
notamondayfan
cheers guys!!
