ross009 0 Posted January 23, 2008 im looking for some new suspension soon and im thinking challenge spec billies with the group n or a rear dampers but where can you buy them from ive read up on them loads on here but cant find where you can get them? Share this post Link to post Share on other sites
Alan_M 66 1 Cars Posted January 23, 2008 Peter Lloyd Rallying You can get the fronts and rears from there. Share this post Link to post Share on other sites
Miles 331 1 Cars Posted January 23, 2008 Me, You can;t get group 'A' rear's only group 'n' or challenge spec but I don;t like using that description as they are a damper designed mainly for off road use but with Eibach springs are very good on the road and track, There used to be Gravel and tarmac spec's but they are all the same now unless you find some very old stock. Share this post Link to post Share on other sites
ross009 0 Posted January 24, 2008 Me, You can;t get group 'A' rear's only group 'n' or challenge spec but I don;t like using that description as they are a damper designed mainly for off road use but with Eibach springs are very good on the road and track, There used to be Gravel and tarmac spec's but they are all the same now unless you find some very old stock. ah right i see! so what would you reccommend for fast road and track? the group n rear dampers then the challenge spec fronts with eibach springs? im guessing when you buy the shocks you dont get springs and top mounts etc? how much do they cost from you miles? you can pm me if you want. cheers Share this post Link to post Share on other sites
Alan_M 66 1 Cars Posted January 24, 2008 Me, You can;t get group 'A' rear's only group 'n' or challenge spec but I don;t like using that description as they are a damper designed mainly for off road use but with Eibach springs are very good on the road and track, There used to be Gravel and tarmac spec's but they are all the same now unless you find some very old stock. Did'nt realise you could get the Challenge shocks! Can you PM me prices of the Challenge spec front shock and Bilstein coilovers? I 'may' need a new drivers front shock (maybe bent from my 'Ring incident), but if the coilover prices are alright I may be after some of thoe instead Share this post Link to post Share on other sites
Nathan_marriott 0 Posted January 24, 2008 (edited) Did'nt realise you could get the Challenge shocks! Can you PM me prices of the Challenge spec front shock and Bilstein coilovers? I 'may' need a new drivers front shock (maybe bent from my 'Ring incident), but if the coilover prices are alright I may be after some of thoe instead Notts lad, Give Shenpar a ring, speak to Nick tell him Nathan Marriott Sent you, good price guaranteed. Tel: +44 (0)1332 862901 Edited January 24, 2008 by Nathan_marriott Share this post Link to post Share on other sites
Miles 331 1 Cars Posted January 25, 2008 Bilstein don't do coil-over's for the 205 only the inserts and people make there own bodies or buy them in from X, odd I know but as with most 205 parts now new ones are few and far between. Share this post Link to post Share on other sites
