Big_Jimbob 0 Posted January 23, 2008 Can anyone tell me the inside bore of these pipes? Im making a heat exchanger for my 205 dt and need to order the correct size pipe... thanks Jim Share this post Link to post Share on other sites
GLPoomobile 958 Posted January 23, 2008 Can anyone tell me the inside bore of these pipes? Im making a heat exchanger for my 205 dt and need to order the correct size pipe... thanks Jim I'm not sure if you mean the metal pipes from the heater matrix to the bulkhead? If you are, I've just measured one (have them laying on the table right now) and they are 16mm. Share this post Link to post Share on other sites
Big_Jimbob 0 Posted January 23, 2008 Sorry mate should have made that a bit more clear... im on about the rubber hose that goes to the bulkhead in the engine bay... the one that usually has the bleeding screw on it.... thanks Jim Share this post Link to post Share on other sites
