Stu
Mocal Oil Cooler Kits: Mi16
Stu
As above peeps, ive had a look through previous posts, and not found a definitive answer, a lot of people use the Mi water to oil cooler and with the finned sump say thats enough.
Im using the water to oil at the mo, with an XU10 sump, and am thinking that being as though i intend to do a few track days this year it'd be wise to upgrade to an air to oil cooler.
I gather the stock 1900 jobbie is no good, so what do we think to this one?
http://cgi.ebay.co.uk/PEUGEOT-205-309-GTI-...oQQcmdZViewItem
Im thinking that with the increased capacity of the XU10 sump and a decent cooler i might just be able to keep the rods inside the block... ;)
James_R
Seems to vary car to car/driver to driver and then again track to track. I found a 13 row item on a tin sump fine for germany but useless really for UK circuits, best off going overkill and getting a 25row and a thermostatic take off, then you have surplus cooling.
The extra capacity will just reduce the rate the oil gets hot, not help with the cooling so much. Start off trying no oil heater and just the alloy sump and see how you go, just put a proper temp gauge in to keep an eye on things.
Stu
I did wonder if the water-oil cooler would heat the water as the running temps are so different, so i think its probably best to isolate the two really.
I want to stick with the XU10 alloy sump for the moment too, simply for the baffle and gate, ive had a look on that link and the guy can supply a 16 row cooler for an extra £7 so i may go for that.
Anymore for anymore?
Garry
My 13 row copes OK, I would suggest though, getting a standalone oil stat as opposed to the sandwich plate type. I have the sandwich plate type and it doesn't seal completely so you are always cooling the oil, resulting in over cooling during road use.
James_R
Unless you do the carboard/ducktape trick which I prefer.
Stu
Lol.. now thats my kind of modding. ;)B)
James_R
just keep covering up the cooler till the oils bang on right ;)
My car also has a 13 row cooler, its fine.
Garry
I can recommend a Crunchy Nut Cornflakes box! B)
LOL,
I'd use a 235mm matrix as I bet the one there is a 115mm item, A std Fitting kit is £50.53 and the listed cooler there is £48.57.
A 235 16row cooler is £74.03 or £58.27 for the slimer version.
But and a very big but, is I always recomend to fit the cooler in a desired location and get the pipes cut to suit as most kit one's I;ve always never fit.
All list price and + VAT which I can offer a nice saving on.
bobob
Would there be any benefit on fitting an oil cooler on a road car? :DB)
Only if you're suffering from high oil temperatures, which is unlikely on the road
returnofjim
I fitted a 16 row to a mi16 on bodies recently and that keeps very cool.
There's always the risk of over cooling the oil if you go too large. I use a 13 row with an extended XU10 sump, in a hot environment. It seems more than adequate for a 5 lap sprint.
By far the best way of reducing engine bay temp's is to lift the back edge of the bonnet, I use a 24 row on mine and on the hotest day it keep's the oil just about right after a 15 min Race
Stu
LOL,
Hmmm.. Interesting, what does the 235 dimension refer to Miles? ive got core dimensions of 235 x 124 for the 16 row cooler in the kit i posted, but im unsure of the depth, so assume when you say a 235 unit you mean the length.
What sort of money could you do me a 16 row kit for bud? PM me if you like.
Batfink
Surely the bonnet rear is a high pressure area so not very effective at ducting air out? I guess if you only need to make a small difference then its a good idea. The other is to properly duct air through the core..
the 235 is the core depth, I'll drop you PM with the price for the various parts tomorrow
But in the ideal world you want the oil cooler in it's own air not infront of the rad etc..
Stu
Yeah, i plan to do that, im thinking underneath the drivers side headlight behind the bumper, with some vents cut into it.
might even take the fog light out and duct some air up to it with a port and a bit of hose of some description.
So just so im clear, what are the dimensions of the cooler? id have though it was 235mm across, by 110mm ish high, and approx 40mm (ish) thick?
Garry
Pretty much, yes.
That makes the install kit useless as the hoses will be far to short and the brackets supplied are poor, So really the cooler and take off is what you need and get some hoses made up by a local pipe company like Pirtek
Stu
Bugger..
how long are the hoses with the kit then Miles? will it go anywhere with access to clean air?
Garry
If its the same as mine, you will only have enough hose to put the cooler infront of the oil filter within the bumper! Have a look on spikys track car build and you will see what I mean.
