Theo205 0 Posted January 19, 2008 A couple of days ago a had a problem when the gasket on the thermostat housing went bad and resulted into oil and water mixing together. Now Ive fixed that and put everything back... But Ive tried for hours to get rid of the slime in the cooling system and IT JUST WONT GO... After I warm it up and take it for a spin the expansion tank looks like this I was told it will need some time to clean but I thought you lads might know any easy way to flush the pugs guts? Thanx Theo Share this post Link to post Share on other sites
Mikey S 29 1 Cars Posted January 19, 2008 i find adding a bottle of washing up liquid to the expansion bottle then running it around usually cleans it out. Share this post Link to post Share on other sites
welshpug 1,666 Posted January 19, 2008 I find using cooling system flush does the trick... Share this post Link to post Share on other sites
saveloy 8 Posted January 20, 2008 i find adding a bottle of washing up liquid to the expansion bottle then running it around usually cleans it out. Oooooooh the bubbles! Share this post Link to post Share on other sites
KRISKARRERA 2 1 Cars Posted January 20, 2008 My radiator was low recently and I topped it up with a half bottle of spring water from in my car and then realised it was what was left of the soluble Solpadeine tablet drink I'd made the other day! At least the engine won't get HEADaches now Share this post Link to post Share on other sites
jackherer 543 Posted January 20, 2008 My radiator was low recently and I topped it up with a half bottle of spring water from in my car Spring (mineral) water is really bad for coolant systems, all the minerals will furr it up loads Share this post Link to post Share on other sites
KRISKARRERA 2 1 Cars Posted January 21, 2008 What's best to use then? The tap water in this area is jam packed full of chalk, kills showers, dishwashers, kettles etc in no time unless you filter the water. Share this post Link to post Share on other sites
jackherer 543 Posted January 21, 2008 Distilled water. Share this post Link to post Share on other sites
jackherer 543 Posted January 21, 2008 Or buy a reverse osmosis filter, if your water is that bad then it could be useful for more than your coolant system. Share this post Link to post Share on other sites
KRISKARRERA 2 1 Cars Posted January 21, 2008 We've got one of these: http://www.h2onics.co.uk/ (first pic in the link page). Seemed to work very well. What's the water like in Cyprus Theo? I'm sure it makes all the women up for some lovin' Share this post Link to post Share on other sites
jackherer 543 Posted January 21, 2008 The one on the bottom right of that page is a reverse osmosis filter. Anything that filters water has to be better than tap water but make sure the thing you have isn't a water softener that adds more stuff to the water. It looks like a magnetic thing which should be fine for use in your coolant system. Share this post Link to post Share on other sites
