DamirGTI
D6b And Dkz Engines ?
DamirGTI
Hi !
I was wandering wheres the difference in between 1.9 D6B and DKZ engines ? :D i know that DKZ engine has "mild" cam but is that all or is there something else like - different piston crowns , combustion chamber depth etc. ?
Why this DKZ engine has lower CR compared to D6B engine ?
Thanks ! :)
Damir
Edited by DamirGTI
  DamirGTI said:
Hi !
Thanks ! :)
Damir
The pistons have a bigger dish to give 9.2:1. It has the same head.
DamirGTI
Then the camshafts are the same ? :D
I have some data for valve lift and there says :
Intake valve lift : 11.3 D6B - 11.0 DKZ
Exhaust valve lift : 11.3 D6B - 11.0 DKZ
Anyway if i fit D6B pistons in DKZ engine it'll have same CR as D6B engine , or not ?
Thanks ! :)
Damir
Thanks ! :)
Damir
No, as you said, the cam is different. They have the similar lift but less duration.
Yes, you could fit D6B pistons to bring the CR up to 9.6:1, but I'd just skim the head if the pistons/liners are in good shape. A skim of 1-1.2mm should give 10:1.
Edited by petert
DamirGTI
Excellent , thanks for info Peter ! :D
Cheers :)
Damir
