daz205
Are Wing Indicators A Mot Requirement?
daz205
hi some little thieving scrot has nicked my rear light clusters and wing repeaters. in nicking the repeaters they have managed to rip/cut the cable so far down i cant get hold of it to connect some new ones, are they needed for an mot and if not whats the best way to fill the holes
also anyone with some phase 1 rear lights for sale please contact me dont really care to much what type i just want the car on the road
James_R
If the front indicators are E marked then you don't need them. Think 205 ones are ok to not need them.
I've got a set of ph1 rear clusters in the garage, £5+postage? is it just the lense bits you need not the reflector+bulb bit yeh?
Edited by James_R
Side repeaters are needed for the MOT. My friends 205 had replacement wings without the repeaters and it passed several MOTs without being noticed but in the end one tester failed it so we bought some nasty chav stick on LED horrors and put them on for the test and took them straight off afterwards. Pre 1986 or something cars don't need them but after that they do.
Think I have a pair of side repeaters. Also the wiring runs through and joins to the wiring for the front indicators, so if you pop the headlights out you should be able to see where it runs, and then hopefully repair it and feed it back through.
damien
sounds about right, my b-reg nova didnt have any side indicators
Jer309GTi
Yep, pre 86 don't need them :)
Paintguy
Thirded. Although I once had an '84 Fiesta fail because of a lack of side repeaters. It wasn't really worth the hassle to get The Ministry involved though, so I just drilled out some holes and fitted a set of cheapo's :)
I have a pair of white Ph 1 lights hanging around somewhere if you get (really) desperate.
